Huh? No more free channels?
Postby niclights » 27 Mar 2009, 12:33
As I said, you need to check that the rate attribute is set to fading in patch/utilities. You also obviously have to manually set the rate channel back down to zero too.
SL
Postby SL » 27 Mar 2009, 13:53
I`m busy with making the personalityfile again ok, but i saw now that i can make the channel also fadeble LTP. Maybe that`s an option?
Postby niclights » 27 Mar 2009, 13:54
Fadeable LTP is exactly the same as what I mentioned above. It is definable from patch utilities.
SL
Postby SL » 02 Apr 2009, 11:27
Thanks for all the help! The patch is completed a few days ago, and it fits.
