Urgent driver
sarassl
Urgent driver
Postby sarassl » 13 Feb 2009, 08:54
is there are any one can help me where can i find the ZOMAX-575-2 DRIVER FOR AVOLITE or i dont how to create own mh driver on avolite can anyone teach me how to do that guys it really urgent :cry:
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
SUPER SOUND & LIGHTS ENTERTAINMENT SERVICES
Postby niclights » 13 Feb 2009, 14:16
Please submit your request at the Personality Library
If you need it immediately then you can create it yourself. Details are in the manual with plenty of discussions here in the forum. You should search for 'personalities' or similar.
Alternatively you could try using Raul's Personality Builder
If you have any difficulty then come back and we can try and help.
sarassl
Tanks & Need Help
Postby sarassl » 16 Feb 2009, 05:12
Dear Sir,
Thanks for your advice on my post but still i have some problem to create
the personality for zomax 575-2, by using the personaliti builder i have
someprob on the creation side like the channel type (HTP, LTP, Instant)
(16bit LTP not fade, 16bit LTP, Part Of A 16bit ch) all those thing i dont know
which one to select, i have send a request on AVO personality request but
till now no reply. i relly hope you can help me as soon as posibble guys.
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
Postby niclights » 16 Feb 2009, 14:22
As a rough guide, you can set Dimmer to HTP and all others to LTP.
16-bit is used for more accurate control and requires two channels. These are then combined within the console. Most commonly they are used for Pan and Tilt.
If your fixture uses 16-bit it will be listed as Pan/Pan Low (fine) and Tilt/Tilt Low (fine). Here you would set Pan & Tilt as 16bit LTP and Pan Low/Tilt Low as "part of a..."
HTP = Highest Takes Precedence.
LTP = Latest Takes Precedence.
I understand English is not your native language but I suggest you Google about HTP and LTP. It is very important that any lighting programmer understands these.
If you're still having difficulty you can post a link to a manual or list the fixture DMX channel assignment here.
zahoorjury
Postby zahoorjury » 16 Feb 2009, 22:54
hi, i can also help you in this, just send me the configration of your light's channels, e.g. Ch. 1= PAN, Ch 2= TILT, Ch. 3= ........ etc. :) :)
sarassl
Help Me PLsssss
Postby sarassl » 17 Feb 2009, 09:26
Channel Listing.
1. Pan
2. Tilt
3. Shutter
4. Dimmer
5. Color
6. Gobo 1
7. Gobo Shake
8. Gobo 2
9. Gobo Rotate
10. Focus
11. Prism
12. Iris
13. Speed
14. Fine Pan
15. Fine Tilt
16. Reset
Pls help me on this china moving head.....thanks alot for your support n Guide Guys
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
zahoorjury
Postby zahoorjury » 17 Feb 2009, 23:04
hi saravanan, go to your hotmail ID, i have sent the personality there. Hope it'll work.
sarassl
thanks alot
Postby sarassl » 20 Feb 2009, 05:54
Dear Sir,
Hi there, the moving head is working now. Thanks alot for your support n guide. bye tc
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
Users browsing this forum: Google [Bot] and 34 guests
