I have a little question about shapes.
When i program a shape on to my fixtures e.g. a circle I use te LTP fade time to let the fixtures go graduatly from there position into the shape but when I run the shape on a playback fader, the moment I put the fader down de fixtures go rapidly back to their original positions. Can I make the pan tilt movement fade out to so that they wil move smoothly to their orignal position?
Or am I just programming wrong??
Thanx..
shape LTP fade out
I'm strugling for a while now with the same problem. So if I read it right here's what i have to do in my situation:
I build a shape wich includes a circle movement without any pan/tilt information recorded on channel mode.
I put the playback parameters on speed timed and size static. cause i want to alter my speed during show.
I'm experiencing that the shape kicks in when i fade it up. making it very ugly to look at. most of the time i work with the dims down of my moving lights but that doesnt work all the time.
So i have to correct the ltp fade time in edit times? Is this correct or do I have to do more?
Cause i tried a lot of stuff but it did'nt work so far.
You must set size to timed.
Then timed fade in can then be set with LTP fade + mode1 (automatic when defining a time), but this will still snap out.
For a smooth fade out you must set to mode2 and manually use the fader. You can do this in conjunction with LTP fade time but it may give strange results.
