smoke machine and haze
hi!can anyone help me wer can i control the smoke machine and haze? wer can i download the personality or maybe i can link to the dimmer? need help pls.
I deleted your original post because it was in the Visualiser section, did not appear to be related to Avolites consoles at all and was written entirely in 'txt' speak.
I will give you the benefit of the doubt this time and suggest you either look in the Personality Database or simply patch dimmers.
Advantages of a personality might be to use LTP and/or to use fewer handles if fixture has more than one control channel but it is not essential.
If your question is can you plug a smoke machine into a dimmer then the answer is no. But this is beyond the scope of this forum.
Haze control
I've found most smokers, foggers, and hazers simply use 2 dmx channels and can simply be assigned to faders by patching dimmers. ie: set your dmx address on a machine to say, 100. Patch handle one at dmx100 and 2 to 101. now you have simple machine control of smoke volume and fan from the console.
The point Nic was making about using a personality (ie not a dimmer) is that the machine (specifically a hazer) could be used LTP. Dial in the value and leave it...hazer levels are unlikely to change throughout a show; plus you save one, probably two handles.
Obviously with a smoke machine, it needs to be on a handle for instant access. Just remember to clear it before programming chases (been there and done that
HTH
Andy
ps As it happens, I prefer dedicated remotes for both smoke and haze, I once had a desk go bonkers and filled a hall up with smoke, unfortunately it wasn't a rave, but a kids thing....
HTH
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
