On the azure what causes this??
I get it every now and then and the only option is to power off and restart
pretty frustrating it usually happens when busking quite fast but the other day
it happened when no one was even near the console
ta
mikey
A : ABORT
- zahoorjury
Re: A : ABORT
Mikeyray wrote:On the azure what causes this??
ta
mikey
Hi , after two years of this post i am also facing this with my console . if any one there tell me how to solve it
- zahoorjury
you people are lucky that you have a dealer or distributer in your country but i dont here,
if someone of you find the solution kindly mention, as this can help AVO USERS around the world
- zahoorjury
A; Abort,
hey, so the problem is apparently this: (according to avolites america)
the board's power supply is going bad, which means when you go to use the floppy (the only moving mechanical part) the board's voltage drops to like 89 volts, which means the board goes into the programming enviornment (like the actual board OS coding enviornment). The way it was explained to me, was that that's how they actually get the board into that programming mode, is that they send it low voltage.
SOLUTION? apparently you have to just replace the power supply. (and possibly the floppy drive if it's been going on for to long and it was damaged?) and maybe have the floppy disc drive control chips also replaced.
- zahoorjury
- zahoorjury
No more A:ABORT
Hi all, specialy Mikeyray & dmb 182, i wrote in my previous post that ,i thinks it is about the power supply. Me and my local technician Mr Sohail Malik, replaced the azure supply with an ordinary PC. supply. Congratulations !. It works, you can also try this with any of your local qualified person who can configure the computer supply for your azure. It is cost only 10 US$ here. After trying this you can go for the orignal. Do it at your first ease so i can get your blessing. Here i am also very thankfull to NICK at Avo UK. Without his help i could'nt fix that out. Hope to hear GOOD soon from you.
Hello. I had this problem little time ago, and I believed that it was Floppy which was broken down, considering that occurred by putting a diskette.
But after change, it was the same thing.
It was acted in fact of a poor contact of a component on support located on the motherboard, approximately under the playbacks faders.
Since, the console functions perfectly.
Without light, it's just radio...
- zahoorjury
Users browsing this forum: No registered users and 142 guests
