Hi
I´d like to edit my SG.DAT file to include a shape.
The shape I want to include is a random shutter closing (Random strobe).
I did look in the file for some help but got stranded on what nuber I should use for the shutter channel.
This is how far o came:
SHAPE "Random Shutter" "RANDOM 1"
? 255 8 0 0 0 0 0
What number should I use insted off "?" ?
And will this work at all?
Pearl Shape file question.
hey niclights, I found one of your old posts (2006):
Using random1 as your pattern could work, depending on what you want:
This is what my random1 looks like:
If you set the strobe channel to strobe, and use this pattern to vary the strobe rate, it might work.
But if you wish to use this shape to just open and close the shutter, this pattern is not the right one. You could try something like:
This is a pattern I just made up, so it's not in your shapefile(yet)
niclights wrote:I won? Woohoo!
So, for the select few who are crazy enough to mess with this, here is complete list of attribute assignment numbers above 8 which are not listed in shapefile syntax comments (probably!):
9 - Gobo1
10 - Gobo2
11 - Gobo1 rotate
12 - Focus
13 - Gobo2 rotate
14 - Colour 2
15 - Shutter
16 - Prism
17 - Zoom
18 - Effect rotate
19 - Frost
PATTERN "RANDOM 1"
3c 10 4 18 32 54 78 65
ffbf ff86 ffdf ffa5 ffbe ffcf ffd0 ff81
5f 42 3e 30 22 1a 9 45
ffc3 ffe3 ffa6 fff0 ff8d ffd1 ffb6 ffc2
PEND
PATTERN "RNDMFLUP"
0 7f 0 0 7f 0 0 0
7f 0 7f 0 7f 0 0 7f
0 0 7f 0 7f 7f 0 0
0 0 7f 0 0 7f 0 7f
PENDThis is a pattern I just made up, so it's not in your shapefile(yet)
Users browsing this forum: Google [Bot] and 24 guests
