D4 Elite legend question
Iain
Postby Iain » 22 Feb 2008, 17:11
Anyone else had a problem with the keyboard becoming disconnected from the board, (not in a physical sense), and being unable to type in a legend. After a restart the problem is solved..........for a while. Iain
:roll:
neil
Postby neil » 22 Feb 2008, 22:53
YES....
Diamond 4 number 0017 (Avo stock).
I re-started it and it worked again.
But I have had this issue before.
No idea why though....
Cheers
Neil
Olie
Site Admin
Postby Olie » 25 Feb 2008, 12:36
There is a problem where the keyboard looses association with the Diamond 4 software. This happens when another window is activated and the keyboard is associated with that application instead.
This is simple to fix, you just need to click on the Diamond 4 software with the mouse and then it will be associated to the keyboard again. There is no need to re-start the console.
Iain
Postby Iain » 25 Feb 2008, 13:05
Thank you, Ollie. 8)
neil
Postby neil » 25 Feb 2008, 13:06
Thanks for that Ollie.
What happens if you don't have an external TFT to hand?
Cheers
Neil
Olie
Site Admin
Postby Olie » 25 Feb 2008, 15:30
You should not be using a Diamond 4 without an external monitor. Ocassionaly important information is displayed on the monitor that you need to read and respond to.
neil
Postby neil » 05 Mar 2008, 22:13
Olie wrote:You should not be using a Diamond 4 without an external monitor. Ocassionaly important information is displayed on the monitor that you need to read and respond to.
Thats most interesting, Ollie.... I wasn't aware of this at all, and don't remember having (ever not even by Avo - until now) been told this.
Problem is, the festivals - and anywhere else, where theres some scaffolding you and not much else!
Thats very much well worth remembering! Thanks Ollie :)
Cheers
Neil
djrappa
Postby djrappa » 28 Mar 2008, 12:41
If however you're being naughty and not using an external monitor, just keep hitting ALT+F4 on the keyboard until it starts working again.
Cheers
Clint Dulieu
Lighting Designer
Warner Village Theme Parks
