D4 Elite legend question
Anyone else had a problem with the keyboard becoming disconnected from the board, (not in a physical sense), and being unable to type in a legend. After a restart the problem is solved..........for a while. Iain
There is a problem where the keyboard looses association with the Diamond 4 software. This happens when another window is activated and the keyboard is associated with that application instead.
This is simple to fix, you just need to click on the Diamond 4 software with the mouse and then it will be associated to the keyboard again. There is no need to re-start the console.
Olie wrote:You should not be using a Diamond 4 without an external monitor. Ocassionaly important information is displayed on the monitor that you need to read and respond to.
Thats most interesting, Ollie.... I wasn't aware of this at all, and don't remember having (ever not even by Avo - until now) been told this.
Problem is, the festivals - and anywhere else, where theres some scaffolding you and not much else!
Thats very much well worth remembering! Thanks Ollie
Cheers
Neil
Neil
