Hi Avo,
Since we have the D7-330 in our venue ( De Boerderij , Zoetermeer, NL ) I ran into this issue:
The Rotary encoders can be assigned as masters, ofcourse, but......
As a Rate master it works fine and I can adjust the rate from 0 to 100% in about one or two turns.
As a BPM master however, the response is terribly slow. It's about 2 or 3 BPM per turn.
Am I doing something wrong here?
Cheers,
Arie
D7-330 rotary encoder issue as BPM master
Re: D7-330 rotary encoder issue as BPM master
It's the same with my D7-215.
I'd like to use the rotary as BPM master, but the rotary value doesn't move.
Bug or configuration ?
Thank you, jlrms
Thank you, jlrms
C'est bien beau de mettre un beau forum en ligne, mais si il n'y a personne pour répondre aux questions, ça ne sert pas à grand chose !
I have reported the problem the the Avo team at the ISE...
