using Quartz
after installing V18 from v17
the side keys A-G keys are not working
there was an error on the usb update process , and i didnt capture the error , pressed retry a few times and eventually it passed
but now the Auxiliary Panel 1 Panel is not showing in the USB Expert
and the side keys are not working...
everything else seems fine
any one knows any thing ?
thank you
Quartz missing USB Auxiliary Panel
Re: Quartz missing USB Auxiliary Panel
It looks like you have already opened a Help Desk ticket regarding this. To avoid confusion it may be best to continue with that.
thank you im with support right now on email but i need to fix this as quickly as possible...
Help Desk is almost certainly the best and fastest way for this as it looks like it is hardware related. I believe you have been contacted by support already.
yes , problem solved , usb driver issue , solved bu help desk . thank you
Same issue after updating my Quartz to v18. Panel update failed on the Auxiliary panel and now has disappeared and isn't functioning. Tried Repair USB Drivers in USB Expert. Was there somewhere else to update drivers? Aux panel doesn't show up in Device Manager either
Users browsing this forum: No registered users and 111 guests
