Copy/Paste Fixture Order
Oz Perrenoud
Postby Oz Perrenoud » 29 May 2025, 10:50
Is it possible to copy a fixture order from one group to another?
Re: Copy/Paste Fixture Order
Postby Gregory » 01 Jun 2025, 23:02
If you select a group the fixture order/layout will go into the programmer, if you either record a new group (e.g. by double tapping) or merging into an existing group the order should go into the new group. When recording into an existing group there is also an option on softkey D Update Fixture Positions from Programmer which will do pretty much what it says and unlike merge will not add any fixtures to the group which aren't already in it.
Oz Perrenoud
Postby Oz Perrenoud » 05 Jun 2025, 16:27
Maybe I explained myself badly or I'm doing something wrong...
I have two groups with the same number of fixtures (12), but they contains different types of fixtures.
I want to copy the twelve positions (order) from the first group (whose fixtures are not present in the second) to the second group.
Is this possible?
Users browsing this forum: No registered users and 82 guests
