Avolite programming question
aliceshea
Postby aliceshea » 18 Jul 2024, 08:17
So I'm programming a show on Avolited Quartz.
Got all of my cues in a cuelist, except a couple that are easier to stick as a single cue or chase on a separate fader so I can throw them with swop/flash.
Problem is that the cues/chases on the other faders involve the colour of LEDs changing, and the colour doesn't go back to what it was before I threw that secondary cue with the swop/flash. Is there a way to get it to go back to the original colour?
Re: Avolite programming question
Postby Gregory » 18 Jul 2024, 23:16
For cues (memories) you can change them to Mode 2 which will fade in and out the LTP attributes following the fader level so when the fader is moved back to zero the values will return to what they were.
The alternative is to set a Release Mask, this runs when a playback is killed (including when the fader is lowered to zero) and fades LTP values back to previous playback values (or back to home values depending on your settings). This can be set globally, i.e. for all playbacks, in the softkey menu after pressing the Release button or release masks can be set individually on each playback which will override the global setting. You can also set a Release Time in both places.
Both mode 2 and release will also apply to flashing and swopping playbacks.
Users browsing this forum: No registered users and 103 guests
