When you attempt to patch through the patch menu then it's recommended to use the search box - simply type 'Forte' when you are in the Fixture Type level:
- forte_1.png (26.76 KiB) Viewed 77950 times
Please note that the 'full name' is
Robin Forte - thus, if you go through the menu with previous/next you need to go to
Robin.
Even easier is the patch view: toggle to the 'Personality List' tab and type 'forte' into its designated search box:
- forte_2.png (45.32 KiB) Viewed 77950 times
As for the flower effect: this is the same thing in every visualiser and for all such fixtures: as far as I know there is none which would simulate such effects. There is simply no description language which could describe such effects, also the manufacturers don't provide those data, and no visualiser has such engine implemented.
