Break group references......
nflutter
Postby nflutter » 01 Jul 2022, 08:09
I'm reading in the manual about 'Break Group References' but I just can't find it on my Mobile or in Simulator.
I'm on v 15.1 and reading from the 15.1 online manual......
If you want to change the fixture order for a particular shape without changing the order in the group, which might affect other shapes, then you can break the link to the group using the Break Group References button in the Edit, Edit Fixtures/Groups, Fixture Order menu.
When I'm hitting Edit all I get on softkeys is 'Edit Palette' on softkey A, that's it.
Has it been moved?
nflutter
Re: Break group references......
Postby nflutter » 01 Jul 2022, 15:37
OK found this now, I was using the Edit hard key, wasn't clear in the manual that it was the Edit softkey within shape generator.... my bad.
However, there doesn't seem to be anything like this for key frame shapes? Any ideas?
Postby Gregory » 05 Jul 2022, 17:22
If you click on the little fixture button to the right of the Key Frame Shape header on the left (highlighted in cyan in the screenshot below), that should take you to options to change the fixture order and add or remove fixtures.
nflutter
Postby nflutter » 05 Jul 2022, 19:25
That's perfect, I'll have a look now.
Thanks again!
Users browsing this forum: No registered users and 120 guests
