Hi, I’m struggling to get a button on a midi controller to act as a tap tempo for a bpm master.
Using Titan V13, T2 with Titan Go.
Bpm master is assigned to a fader, and the swop button on the playback works fine.
Set up a trigger, assigned a button (tried both control change and a note) to the swop button, but it hits straight up to 360bpm on Titan.
Any ideas? Or do I need to upgrade to fix?
Tap tempo with midi trigger
Re: Tap tempo with midi trigger
I have just answered this in the facebook group:
Currently you cannot trigger masters, nor can you trigger macros, as item. However you can solve your problem using a macro:
This way your trigger fires the macro which taps the master. Works for me
- define (create) the BPM master
- get the BPM macros file from https://www.avolites.de/wiki/_export/co ... odeblock=0 and make them available (described in the wiki)
- copy the Tap BPM X macro to a macro button or playback button
- you may already try to see that this macro works
- now define the trigger to fire this macro. This needs to be Trigger Type hardware.
Users browsing this forum: Google [Bot] and 78 guests
