Hello all,
One question: I'm in the following situation and I can't figure it out.
chase made like this:
step 1: 2 heads with dim 100 and col via pallet red
step 2: 2 heads with dim 100 and col via pallet red
and so on up to 4 steps.
so a chase of 4 with dim and col. Cue release on and mask on int. and col.
and this works well if I have my base col also a nested pallet directly from the pallet but....
if I open a fader a bit with just all heads on dim 100 (fader mode 2, mask release ints on) the following happens.
from the moment the dim fader comes up, the dim of the chase in the step also goes to the value of the dim fader. and I want the dimming value of the chase to stay ontop but the color value to change.
Is there a solution for this?
the intention is that I run a colorchase with dimming values in it, but that I can put a different color under it with a lower dimming value with 1 fader (which only contains the dimmers of the devices)
I also work with chamsys and there this is possible and without many problems. I just don't see how I can do this with avolites.
So anyone with tips and tricks?
chase dim and color and a dim value in the background doesn't getting in right
bertes1979
bertes1979
Re: chase dim and color and a dim value in the background doesn't getting in right
o yes, i am using a T2 with version 15 and Titan Go
