Hi
I'm stuck on something and can't find the answer in the manual... it's possibly there but I can't find it, so apologies for the possibly daft question.
When I have a couple of chases running from the rolacue playbacks, how do I adjust the speeds (and attack parameters) of any particular running chase? Normally if I just have one running, when I trigger it the wheels take on the 'speed' and 'snap/fade' attributes for that one, which is great, but inevitably when doing something else the wheels lose that; particularly if I trigger another chase then these wheels will relate to the latest chase and I can't change the previous one.
Is there a way of adjusting running chases at all please?
I think it might have something to do with the connect button but in the heat of the gig (and indeed when playing during setup) I can never find a way of changing the speed from that which it's saved as. What am I missing?
(On a similar note, does anyone know when the 'tap twice to (change speed' bug will be ironed out, as mentioned here: http://avolitesshop.co.uk/phpBB3/viewtopic.php?t=465 ? 'The next release of the software' - am I right in thinking though that the current software is still 1.2 and has been since 2005?)
Many thanks
Peter
PS I'm using a Pearl 2000 with 2004 software, 1.2 I think.
Changing chase speeds
pscandrett
Freelance lighting designer/op/technician based in Manchester - http://www.scandrett.net/
ok, here we go:
=> change the roller to the facet that has the RUNNING chase (it MUST be running => fader above 10%)
=> press connect
=> press the swap for the chase/playback
=> now you should have control with the wheels, Unless you've disabled wheel-control in the chase paramaters. for that chase.
=> press connect
pscandrett
Great, thanks, I'll try that later. I thought it was something like that! Ta for the quick response, too.CoenCo wrote:ok, here we go:
Note that you do not have to change the roller to the originating page. You can connect to any running chase denoted by a flashing Swop LED.
However, there is currently a bug where the desk will only allow you to connect when the relevant playback on other pages also contains a chase. When you have changed page and the playback does not contain a chase the Swop will not flash and you cannot connect. In this case you must either change back to the originating page or to one that has a chase on the associated playback.
