MIDI triggers glitch with long notes?
kimoto
Postby kimoto » 02 Apr 2021, 07:03
Nice to meet you.
I am a user of Avolites Quartz.
My day job is as a musician, so I use MIDI Trigger to call Cue and create light effects.
But now I have a problem and I need some advice from an experienced user.
Situation:
I want to use the MIDI Trigger function to call up the Cue in Avolites Quartz (V13.0).
The MIDI control software is APPLE Logic Pro X.
I'm making a lighting show.
Problem:
I can control short notes without any problem, but for longer notes, the note off is not recognized and Cue is still pressed.
This may be a special usage, please help.
(This text is a translation.)
kimoto
Re: MIDI triggers glitch with long notes?
Postby kimoto » 09 Apr 2021, 01:01
I'm writing this because I solved it myself.
(I've checked it on multiple Quarts, so I've decided it's not a machine problem.
The Cue on the fader seems to delay it with MIDI, but if I put it in Playback, the problem doesn't seem to occur.
I don't know the cause, but this seems to solve the problem.
(Translation)
Postby icke_siegen » 09 Apr 2021, 06:59
Hi kimoto,
good to hear you solved it.
Can you please describe how you defined the triggers? Did you use trigger type hardware or trigger type item? and which trigger action did you choose?
Thanks, Sebastian
