Titan One: Size Master 1 controls fixture-group
Hans48
Postby Hans48 » 02 Jan 2021, 20:14
In my mixed fixture set (LED PAR-Cans, Wash Heads, Spot & Beam Heads) I wish to control only a permanent group of Spot & Beam Heads by a "Size master 1" fader. A "Grand Size Master" is undesired. How can I get this work? My software is Titan One v.14
Re: Titan One: Size Master 1 controls fixture-group
Postby niclights » 02 Jan 2021, 20:33
You can assign specific size masters to playbacks in the playback options ([Options -> <select playback> -> [Effects] -> [Size Source]).
Hans48
Postby Hans48 » 02 Jan 2021, 21:23
Thanx niclights! But if I control a playback by any Size Master, all contained Moving Heads will be affected. That´s just not what I desired. Only the Spot & Beamheads in all Playbacks should be on "Size Master 1".
The function I´m looking for is like the setup and the use of a Scale Master, this not controlling Intensity but P/T instead.
