Bump Replacer
Bart K
Bump Replacer
Postby Bart K » 28 Mar 2020, 16:26
Hey Guys,
In this strange times Im editing my main Avo show file.
Wrote some Color bumper macro's. They select a 'all fixture' group, select a color, record that color in the bump spot.
Now it replaces that spot, with the line: Palette.StoreCurrentPaletteReplace
To take it a step further, I want to write some macro's to merge some zoom/strobe/iris pallets in to the same spot. To make some different chases on a busk show.
So instead of replace the color bump, I need to merge it. I replaced the ''paletteReplace'' line with Palette.QuickMergePalette, but somehow it stays now in the blind and don't clear the programmer anymore.
Is this the correct line to use?
Any tips are more then welcome, thanks in advance!
Stay stafe guys.
Cheers,
Bart
Re: Bump Replacer
Postby icke_siegen » 29 Mar 2020, 09:00
Hi Bart,
if you could post the code then we could have a look. Also, you may send me the show by email: s.beutel@trendco.de
That it stays in blind means that the macro breaks at some point which may be due to everything: a typo, a wrong comma or quote somewhere, a missing argument... Usually iId have a look in the logs with the log viewer - this is not very verbose but may help identifying the culprit.
And another note: I guess quickmerge is not what you need here as it only updates the attributes which are already in this palette. You might need something like
Palette.MergeCurrentPalette()
Best regards, Sebastian
Bart K
Re: Bump Replacer
Postby Bart K » 29 Mar 2020, 13:02
Hi Sebastian,
I just send u an email with my showfile.
In addition I post here the macro where Im talking about. So other people can read along.
Thanks in advance!
Cheers,
Bart
Colour.White.Bumper.xml
(989 Bytes) Downloaded 2982 times
Re: Bump Replacer
Postby icke_siegen » 29 Mar 2020, 16:30
I had problems sending an email reply hence I post it here:
Hi Bart,
I had a look into this. But there is no such line you mentioned in the forum - I see the additional macros (for zoom and shutter/strobe), but these are recorded ones. So far it looks like they are working okay. So, what exactly can I do for you? What is the problem you need a solution for?
Best, Sebastian
Bart K
Re: Bump Replacer
Postby Bart K » 29 Mar 2020, 21:25
Hi Sebastian,
No problem. I will write down some further information.
Now, when I fire a ''bump'' color from my playback window. It calls a color from the ''All Fix'' row. Then it replaces that color into the ''bump1'' color.
When I add a strobe/zoom/iris pallet with the recorded marcro's and merge them into the ''bump1'' color, its fine.
But when I select a new 'bump' color from my playback window, it replaces the ''bump1'' color, so it overwrite the strobe/zoom/iris information.
I want the strobe/zoom/iris information to be still in the ''bump1'' color pallet, when I select a new ''bump'' color from my playback window.
So I think that the Palette.StoreCurrentPaletteReplace need to be changed for something liek Palette.StoreCurrentPaletteMerge. So the rest of the pallet information stays in there.
I hope I explained it well, so u kind of understand what I want, haha.
Thanks already Sebastian!
Cheers,
Bart
Re: Bump Replacer
Postby icke_siegen » 29 Mar 2020, 21:32
I guess
does this. I'll check myself :D
Re: Bump Replacer
Postby icke_siegen » 30 Mar 2020, 13:06
I tried it and - if I understand correctly what you are wanting - it does exactly what you ask. I sent you the amended macro file yesterday - please have a try.
Bart K
Re: Bump Replacer
Postby Bart K » 30 Mar 2020, 15:40
Tried it. Works perfectly.
Many thanks Sebastian.
jsustrunck
Re: Bump Replacer
Postby jsustrunck » 07 May 2024, 19:09
Four years later....
I'm also very new to coded macro's. You are describing exactly the thing I'm looking for a long time. I tried the macro Colour.Bumper.xml you posted before. But it indeed doesn't work and stays in blind mode. Could you share the correct macro? Or if you don't want to, tell me what the problem was?
Or maybe some else who's got this working?
Thanks in advance.
Andrés Félix
Re: Bump Replacer
Postby Andrés Félix » 07 May 2024, 19:27
I find one way !is replace the playback ?
Re: Bump Replacer
Postby icke_siegen » 07 May 2024, 21:43
I just retrieved the macro file which I sent to Bart. Let me have a look into the details, and I'll post it somewhere tomorrow, okay?
jsustrunck
Re: Bump Replacer
Postby jsustrunck » 08 May 2024, 07:16
icke_siegen wrote:I just retrieved the macro file which I sent to Bart. Let me have a look into the details, and I'll post it somewhere tomorrow, okay?
Sounds great!
jsustrunck
Re: Bump Replacer
Postby jsustrunck » 28 May 2024, 09:36
Hello, did you managed to find some time to take a look at the above?
tygo
Re: Bump Replacer
Postby tygo » 23 Jan 2025, 08:40
Hello, I'm working on a bump macro for color, but it replaces the palette, and the color is no longer in the palette. Can someone help me? this is my macro
<avolites.macros>
  <macro id="Colour.test 1.3" name="Colour test 1.3">
    <description>Bumps true different colours</description>
    <sequence>
      <step pause="0.01">ActionScript.SetProperty.Boolean("Programmer.BlindActive", true)</step>
      <step pause="0.01">Programmer.SetBlindMode(false, 0)</step>
      <step pause="0.01">Group.RecallGroupNumeric(1) </step>
      <step pause="0.01">Palette.ApplyPalette("Location=Colours,1,4", false)</step>
      <step pause="0.01">ActionScript.SetProperty("Palette.CurrentPaletteHandle",Handle:"Location=Colours,1,20")</step>
      <step pause="0.01">Palette.StoreCurrentPaletteReplace()</step>
      <step pause="0.01">Programmer.Editor.Clear(Attribute.Mask.Clear.Value, Programmer.Editor.Fixtures.Clear.Presets, false, Expert.ClearMenu.FadeTime)</step>
      <!--  clear  -->
      <step>ActionScript.SetProperty.Boolean("Programmer.BlindActive", false)</step>
      <!--  exit blind  -->
      <step>Programmer.SetBlindMode(false, 0)</step>
    </sequence>
  </macro>
</avolites.macros>
Re: Bump Replacer
Postby Gregory » 23 Jan 2025, 22:30
tygo wrote:Hello, I'm working on a bump macro for color, but it replaces the palette, and the color is no longer in the palette. Can someone help me? this is my macro
Most likely it is the Palette.StoreCurrentPaletteReplace() function that is tripping you up, internally it is is used when pressing the Replace softkey in the Record Palette menu and as such it will follow what has been configured in that menu. In particular if an attribute mask has been set in that menu previously it will still get used until it is changed, if the mask excludes colour this will not get stored in the palette. You could add a call to SetAllGroups to include all attribute groups in the record Palette attribute mask:
<step pause="0.01">Attribute.Mask.Palette.SetAllGroups()</step>
Alternatively you could set the mask to just colour with the following:
<step pause="0.01">Attribute.Mask.SetMask("Palette", "C")</step>
