Can't open the trigger window
EdlerDurst
Postby EdlerDurst » 30 Jan 2020, 07:11
Console: The new T1
Software: Titan Go 12.1.8.5
When I try to open the trigger window it never open in the current show.
In a new show I can open it as expected.
Is there a option to deactivate it or is it a bug?
Screenshot:
https://imgur.com/a/WME2vrl
phb
Re: Can't open the trigger window
Postby phb » 30 Jan 2020, 10:26
Are you sure it isn't opening on a secondary screen?
Pete Bridgman :: Avolites
EdlerDurst
Postby EdlerDurst » 30 Jan 2020, 13:27
Thanks for your quick response.
I use a laptop with external monitor but I dont expand the laptop screen and use the external monitor as the only screen.
Is there a option to show which window is allocated to which screen?
phb
Postby phb » 30 Jan 2020, 15:12
Unfortunately not. To help verify what's going on, you could disable the external screen (under [System]) to ensure that the triggers window is opening on the screen you're expecting. If you still can't see it after that there might be something more wrong.
