Hi!
how to do this.. 4 moving heads move from A to B
4 moving heads. each start at different timing from point A.. but ends at the same time at point B. ( dimmer and position)
and its a memory not chase. i saw this but no idea at all how to do it.
thank you.
need help on programming tips
For clarity I originally received this as PM. This was my reply:
Hi.
I don't see how this is possible. The only way to achieve is to program a chase carefully but I wouldn't envy you! You can get offset starts by using a shape (and therefore just a memory), but finish time will be offset by the same amount as start and it will repeat.
I think you must be talking about a Diamond 4 and not a Pearl as I can see no way to achieve this with a Pearl. As niclights only operates Pearls he was probably not the best person to contact. Could you confirm which desk you are talking about and I will try and answer your question.
As a general rule in this forum unless otherwise stated, posts are generally assumed to be about the Pearl series of consoles.
am i missing something?
This just done by using a pan-saw shape with offset around a central position.
But that would be too simple! I guess I did not figure the problem correctly...
Dom
Dom
