need help on programming tips
kumar
Postby kumar » 08 Oct 2006, 06:41
Hi!
how to do this.. 4 moving heads move from A to B
4 moving heads. each start at different timing from point A.. but ends at the same time at point B. ( dimmer and position)
and its a memory not chase. i saw this but no idea at all how to do it.
thank you.
Postby niclights » 08 Oct 2006, 13:42
For clarity I originally received this as PM. This was my reply:
Hi.
I don't see how this is possible. The only way to achieve is to program a chase carefully but I wouldn't envy you! You can get offset starts by using a shape (and therefore just a memory), but finish time will be offset by the same amount as start and it will repeat.
Olie
Site Admin
Postby Olie » 10 Oct 2006, 13:13
I think you must be talking about a Diamond 4 and not a Pearl as I can see no way to achieve this with a Pearl. As niclights only operates Pearls he was probably not the best person to contact. Could you confirm which desk you are talking about and I will try and answer your question.
As a general rule in this forum unless otherwise stated, posts are generally assumed to be about the Pearl series of consoles.
Postby niclights » 10 Oct 2006, 15:06
Good point! I did automatically assume was a Pearl.
kumar
Postby kumar » 17 Oct 2006, 17:11
i'm very sure its a pearl, cause i saw it in front of me, maybe he used the shape generator..
thanks guys.
regards
Kumar
Olie
Site Admin
Postby Olie » 18 Oct 2006, 10:32
If it was a Pearl then I want to know how it was done now as well.
The only way I can think of doing this would be with a custom shape or timing attributes on the PT in the light.
kumar
Postby kumar » 18 Oct 2006, 10:36
ok... will try my best to find out. will let you guys know..
till then .. see you guys
regards
kumar
dombleu
am i missing something?
Postby dombleu » 03 Mar 2007, 23:12
This just done by using a pan-saw shape with offset around a central position.
But that would be too simple! I guess I did not figure the problem correctly...
Dom
Postby niclights » 04 Mar 2007, 02:59
Shapes are repeating.
You misunderstood:
There is currently no way to do this on a Pearl.
