firing playback
mathiaskristensen
firing playback
Postby mathiaskristensen » 29 Dec 2019, 20:50
is there a way of firing an onscreen playback using the go button?
or do i have to make playbacks into cue lists to do so
Re: firing playback
Postby Gregory » 30 Dec 2019, 18:30
It is not possible to connect cues to the Go button (and wheels section). On-screen playbacks are normally set to Latch by default when you select them or you can change them to Flash using key profiles.
Users browsing this forum: No registered users and 60 guests
