is there a way of firing an onscreen playback using the go button?
or do i have to make playbacks into cue lists to do so
firing playback
mathiaskristensen
Re: firing playback
It is not possible to connect cues to the Go button (and wheels section). On-screen playbacks are normally set to Latch by default when you select them or you can change them to Flash using key profiles.
