I bought tiger touch console. It is currently running version 9.1. I want to upgrade to version 11.1, what should I do? Do you need to buy a license? Thanks for the help someone!
Mail: huyvhct@gmail.com
Tiger Touch Help !
Re: Tiger Touch Help !
Version 10 onwards requires the Pro upgrade for the Tiger Touch. A basic check is how many network ports there are on the back of the console, Pro consoles will have two. You will also require 4GB of RAM and the UPS board installed, when you run the recovery it will check these things are correct before you install. You should be able to purchase the Pro motherboard upgrade if you need it from your local distributor.
If your console is already compatible you should be able to run the v11.1 recovery and then apply for a new licence, the licence itself should not cost anything. If you wish to upgrade to v12.0/v12.1 you will need to purchase an AvoKey as well.
Tiger touch
Using powerful Titan operating system
DualCore processor, 64GB high-speed SSD, 4GB of memory
Menu display with built-in many languages
A built-in 15.6 inch touch screen HD resolution, which supports the control of various lighting 3D visualization software from th internet to computer
Support Artnet network function
The console comes with 4/8 DMX outputs interfaces
2048DMX channels
Built-in USP power supply, incase of no access to 220V AC, the power supply can operate normally about 1 hour
10 macro function buttons, can edit any program
Putting 20 playback, support more than 1000 virtual replay
Powerful CMY palette
Fast and easy to use graphics generator, classification of built-in graphic easier to use
Support wi-fi access, wireless light control, mobile devices (smart phone, smart tablet) remote control lamps
Built-in lamp library, lamp library editing software
Support MIDI time code sound and light synchronization function.
Size: 650 x 440 x 160 (mm)
Weight: 14 kgs
2048DMX channels
Weight: 14 kgs
My pic
- Attachments
- 2.jpg (245.86 KiB) Viewed 69707 times
- 1.jpg (237.18 KiB) Viewed 69707 times
- sideshowbond
if I was you - after showing those pictures - I'd better be prepared to answer questions where this console comes from as it is as obvious as a fake can be
Gregory wrote:Version 10 onwards requires the Pro upgrade for the Tiger Touch. A basic check is how many network ports there are on the back of the console, Pro consoles will have two. You will also require 4GB of RAM and the UPS board installed, when you run the recovery it will check these things are correct before you install. You should be able to purchase the Pro motherboard upgrade if you need it from your local distributor.
Tiger touch
2048DMX channels
My pic
- Attachments
- 2.jpg (245.86 KiB) Viewed 69650 times
- 1.jpg (237.18 KiB) Viewed 69650 times
- sideshowbond
mate it's a fake console, you won't get much support for that
sideshowbond wrote:mate it's a fake console, you won't get much support for that
Thank you for letting me know that. how to identify real and fake on a tiger touch console
- sideshowbond
not gonna go into much detail but if you compare pictures with a real one the DMX connectors give it away pretty instantly.
You should try to get your money back and email ric@avolites.com with details where you got this console from.
clublights
One clue
it doesnt say Avolites anywhere on it.
sideshowbond wrote:not gonna go into much detail but if you compare pictures with a real one the DMX connectors give it away pretty instantly.
thks
