Timecode stops after 15 minutes
daanvg98
Postby daanvg98 » 23 Dec 2019, 10:28
He guys,
I am programming timecode right now and when the time hits 1:15:00:00, the console kills the playback. But the timecode still continues to run like normal. Right now using midi timecode. Anyone here who has a solution for that?
Thanks,
Re: Timecode stops after 15 minutes
Postby Gregory » 23 Dec 2019, 18:14
If you are recording timecode, you may want to disable the timer so that the console does not attempt to follow the incoming timecode at the same time. This in conjunction with the Kill out of range playbacks setting can cause the playbacks to be killed unexpectedly.
