Visualiser.Capture.ExportCurrentProject
sideshowbond
Postby sideshowbond » 20 Nov 2019, 15:48
trying to figure this one out.
How would I need to format its arguments?
Re: Visualiser.Capture.ExportCurrentProject
Postby Gregory » 22 Nov 2019, 19:58
The first argument is a custom type which represents a drive on a particular console, unfortunately there is not a way of defining this in macros or WebAPI. It is normally created when you select a drive in the menu, you may be able to use a property set the previous time the menu was used, which is Expert.CaptureVisualiserSettings.Export.Drive. Another property which you might be able to use is Windows.ShowFileBrowser.SelectedDrive from the Show Browser window, in either case they would need to be initialised before they can be used.
sideshowbond
Postby sideshowbond » 25 Nov 2019, 09:20
ok, so not really useful for what I thought to do. Actually it's not that important anyways. Thanks :)
