Palette.RecordPaletteReferences
sideshowbond
Postby sideshowbond » 18 Nov 2019, 22:06
I am trying to toggle nested palettes via macro (or 2 macros respectively)
I figured as much as
ActionScript.SetProperty(Palette.RecordPaletteReferences, True)
needs to be a string however parsing the show.xml comes up with boolean values.
Bit stumped I am, any insight would be cool :)
Re: Palette.RecordPaletteReferences
Postby icke_siegen » 19 Nov 2019, 06:43
i'd expect this to be a boolean. Also, the property name needs to be in quotes.
how about this:
ActionScript.SetProperty.Boolean("Palette.RecordPaletteReferences", True)
sideshowbond
Postby sideshowbond » 19 Nov 2019, 09:02
Bingo, rookie error.
Log viewer was telling me something about a Boolean values it was expecting as string, hence my unsophisticated guess...
      <active binding="{propertyLink id='Palette.RecordPaletteReferences' converter='Math.NotConverter'}"/>
      <sequence>
         <step>ActionScript.SetProperty.Boolean("Palette.RecordPaletteReferences", False)</step>
      </sequence>
works brilliantly now
I'll put this in my groups window (where all my other programming macros are) to quickly toggle between nested on or off :)
Postby Gregory » 19 Nov 2019, 13:40
If you wanted it to toggle you could do this:
ActionScript.SetProperty.Boolean("Palette.RecordPaletteReferences", !Palette.RecordPaletteReferences)
This might work quite well in conjunction with the active indicator.
sideshowbond
Postby sideshowbond » 20 Nov 2019, 15:45
Genius, thank you.
