Transferring from Titan One to Titan Mobile
Danielllhurst
Postby Danielllhurst » 01 May 2019, 14:02
Is it possible to transfer data such as playbacks and settings from Titan One to Titan Mobile if we plan on upgrading?
Thank you!
Re: Transferring from Titan One to Titan Mobile
Postby Gregory » 01 May 2019, 15:14
Show files are compatible between all Titan consoles providing they are on the same version or newer. If it is on the same computer, TitanOne and Titan Mobile, will share the same show files directory so you can load them directly from there, otherwise you can save the show to a USB stick to transfer it to another computer. Your settings, workspaces and playbacks will be carried across (the 10 on-screen TitanOne faders will be the 10 physical faders on the Titan Mobile); the only thing you may need to do is to change your DMX Settings under System to use the ports on the Titan Mobile and make use of the additional lines.
Danielllhurst
Postby Danielllhurst » 01 May 2019, 15:49
This is perfect thank you!
Users browsing this forum: Google [Bot] and 232 guests
