Hello evereybody,
I'm a new user on Titan mobile and I created memories on my Titan Mobile. Everything works fine but when I use a fader on a page,and change the page and move the same fader for another memory on a other page, the first memory on the first page is affected.
I'd like to modify differents memories on different pages using my ten fader.
Is it possible ?
Could you explain me how ?
Thanks for your help !!
Fader on different pages on Titan Mobile
s.schroeders
Re: Fader on different pages on Titan Mobile
This behaviour is referred to as the handle being held over and is default on all Avolites consoles without motorised faders. You can change this in User Settings under Handles by changing the Playback Paging from Normal to Never Hold.
s.schroeders
Thank you Gregory for your perfect and quick answer !!
Titan Simulator doesn't allow me to make 2 buttons on the same time so I cannot go to Users setting (Avolites Button + C Key at the same time).
I'll try at home with my titan mobile tonight !
Thanks again !!
Thanks again !!
If you are using the Virtual Panel you can right click on a button to hold it down or you can use the keyboard shortcut Alt+A to open the Avo menu. Alternatively you can find the User Settings window in the Open Workspace Window menu (softkey F) or you can also get to user settings in System by pressing Alt+Shift+S.
s.schroeders
It works fine, thx a lot for your time !
