I am getting to be crazy ... with the Pearl simulator
As I can copy or photocopy a memory situated in the first roller to the second roller?
I have v1.2 of simulator running in a Win Me
Problem with Pearl Simulator
Easy.
For a Copy:
1- Push the ADD button of the original memory or chase with the right button of your mouse. The display will say Hit a <Playback Swop> to make a Link
2- Push the SWOP button of the destination of your choose with the left button of your mouse.
The copy is done
For a Photocopy:
1- Push the PHOTOCOPY button. The display wil say Photocopy 1. Press and hold a <Playback Add>
2- Push the ADD button of the original memory or chase with the right button of your mouse. The display will say Photocopy 2. Then hit a <Playback Swop> (page can be changed)
3- Push the SWOP button of the destination of your choose with the left button of your mouse.
The photocopy is done
Notice that in both cases you can change the page or move the roller in between of the Add and the Swop pushings.
Good luck
For a Copy:
The copy is done
For a Photocopy:
Good luck
Low_ID
litux
I have checked that in the Simulator you can change between all the ten facets of a page (you can do that by dragging the roller with the mouse as you do it with your hand in the real desk), but you can't change the page itself because in every attemp selecting a new one with the left button of the mouse the system escapes the operation.
This feature is working with the real Pearl, and should be working also in the Simulator, so I expect that the software developing team will take note and will fix this inconvenience in the future, as well as others like the groupped sellection in the second row of faders.
Low_ID
