Hi.
Is possible to create a MACRO to INCREASE or DECREASE the RATE MASTER?
Taping on the macro should INCREASE (or DECREASE) the percentage of the RATE MASTER.
I have "half solution": Create new key profile for Rate Master, blue key=NUDGE UP, gray key=NUDGE DOWN, create macros for click on blue key and other for gray key. It works (up or down 10%) but Rate masters must be on selected FADERS PAGE (page 1), if I move Rate Masters to page 2 and go back to page 1 don't work.
Solution for "half solution": if i'm on FADERS PAGE 1 and I move Rate Master to page 2 can create a macro: GOTO PAGE 2 + click blue key (NUDGE UP) + GOTO PAGE 1.
But it would be better having a "global macro" to do this. (MACRO = Rate Master 1 up).
v10.1
Thanks.
Macro Rate Master
acetaxidriver
Re: Macro Rate Master
Essentially this should be possible.
- macro questions are best answered here: viewforum.php?f=20
- http://www.avolites.de/wiki/macros:example:bpmmasters should give you an idea how this might be acchieved and how coded macros work
- if you could be a little more specific about how you'd expect the macro to behave, this would be awesome
acetaxidriver
What I want is:
MACRO 1= nudge RATE MASTER 1 up;
MACRO 2= nudge RATE MASTER 1 down;
I created macros for RATE MASTER and SIZE MASTER
To have small nudge steps (5%) I set SCALE=100% and if the effect is to slow set EFFECT SPEED to 2x (or more)
SCALE: [ Playback options ] + select master + [Scale 0 to 100%]
EFFECT SPEED: [ View ] + select playback + select EFFECT SPEED column + [ x2 ]
<?xml version="1.0" encoding="utf-8"?>
<avolites.macros xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="Avolites.Menus.xsd">
<!-- RATE MASTERS -->
<!-- Rate Grand Master: titanid=1604 -->
<!-- Rate Master 1: titanid=1608 -->
<!-- Rate Master 2: titanid=1612 -->
<!-- Rate Master 3: titanid=1616 -->
<!-- Rate Master 4: titanid=1620 -->
<!-- http://www.avolites.de/wiki/macros:types:object:handle:titanid -->
<!-- Created by: Alberto Faria Costa -->
<macro id="Avolites.Macros.RateMasterNudgeUp" name="RATE MASTER UP">
<sequence>
<step>Masters.NudgeUp(1604)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.RateMasterNudgeDown" name="RATE MASTER DOWN">
<sequence>
<step>Masters.NudgeDown(1604)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate1NudgeUp" name="RATE 1 UP">
<sequence>
<step>Masters.NudgeUp(1608)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate1NudgeDown" name="RATE 1 DOWN">
<sequence>
<step>Masters.NudgeDown(1608)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate2NudgeUp" name="RATE 2 UP">
<sequence>
<step>Masters.NudgeUp(1612)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate2NudgeDown" name="RATE 2 DOWN">
<sequence>
<step>Masters.NudgeDown(1612)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate3NudgeUp" name="RATE 3 UP">
<sequence>
<step>Masters.NudgeUp(1616)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate3NudgeDown" name="RATE 3 DOWN">
<sequence>
<step>Masters.NudgeDown(1616)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate4NudgeUp" name="RATE 4 UP">
<sequence>
<step>Masters.NudgeUp(1620)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Rate4NudgeDown" name="RATE 4 DOWN">
<sequence>
<step>Masters.NudgeDown(1620)</step>
</sequence>
</macro>
</avolites.macros>Code: Select all
<!-- SIZE MASTERS -->
<!-- Size Grand Master: titanid=1606 -->
<!-- Size Master 1: titanid=1609 -->
<!-- Size Master 2: titanid=1613 -->
<!-- Size Master 3: titanid=1617 -->
<!-- Size Master 4: titanid=1621 -->
<macro id="Avolites.Macros.SizeMasterNudgeUp" name="SIZE MASTER UP">
<sequence>
<step>Masters.NudgeUp(1606)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.SizeMasterNudgeDown" name="SIZE MASTER DOWN">
<sequence>
<step>Masters.NudgeDown(1606)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size1NudgeUp" name="SIZE 1 UP">
<sequence>
<step>Masters.NudgeUp(1609)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size1NudgeDown" name="SIZE 1 DOWN">
<sequence>
<step>Masters.NudgeDown(1609)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size2NudgeUp" name="SIZE 2 UP">
<sequence>
<step>Masters.NudgeUp(1613)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size2NudgeDown" name="SIZE 2 DOWN">
<sequence>
<step>Masters.NudgeDown(1613)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size3NudgeUp" name="SIZE 3 UP">
<sequence>
<step>Masters.NudgeUp(1617)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size3NudgeDown" name="SIZE 3 DOWN">
<sequence>
<step>Masters.NudgeDown(1617)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size4NudgeUp" name="SIZE 4 UP">
<sequence>
<step>Masters.NudgeUp(1621)</step>
</sequence>
</macro>
<macro id="Avolites.Macros.Size4NudgeDown" name="SIZE 4 DOWN">
<sequence>
<step>Masters.NudgeDown(1621)</step>
</sequence>
</macro>
</avolites.macros>Thanks
Wow, this looks great. May I post this in the wiki, too?
Are there any questions now?
acetaxidriver
Yes, you can post on wiki.
Please keep credits: Created by: Alberto Faria Costa
Thanks for the tip.
Thanks for the tip.
alexgon.lux
HOLA AMIGOS , ESTOY BUSCANDO UN MACRO RATE 1UP ,MACRO RATE 1DOWN VERSION 17, MUCHAS GRACIAS
Users browsing this forum: No registered users and 61 guests
