Chase over cue
acetaxidriver
Chase over cue
Postby acetaxidriver » 26 Mar 2018, 23:36
Hi.
I have a playback with "DIMMER 100%" turning on 8 fixtures, let's call it "LIGHTS ON".
I have a chase with the same fixtures called "LEFT TO RIGHT", turning ON/OFF from left to right.
It's possible having cue "LIGHTS ON" always on and run the chase over that playback and when turn off the chase it still "LIGHTS ON" ?
AC
Re: Chase over cue
Postby niclights » 26 Mar 2018, 23:58
Not at the moment. The highest dimmer level will take priority. Perhaps you could try using shapes instead of chases?
acetaxidriver
Re: Chase over cue
Postby acetaxidriver » 27 Mar 2018, 08:54
In DIMMER SPREAD it seems to be a cross fade, can remove it?
Re: Chase over cue
Postby niclights » 27 Mar 2018, 09:15
I'm not sure if I fully understand what you mean but if you want a snapping effect you can use the step or pulse shapes or make a key frame shape.
acetaxidriver
Re: Chase over cue
Postby acetaxidriver » 27 Mar 2018, 09:21
SOLVED
Key frame do the trick.
