I think it's easy but I search already a long time for the solution and can't find it...
I created a cuelist. When I open the handle the cue list is loaded and with the GO button each time the next cue runs.
What I want to achieve is that each cue runs automatically after the other.
Had a look in the manual but only find things to start a cuelist on a specific time.
Run cuelist automatically
Re: Run cuelist automatically
Culelist "Link" option : "Link Wait For Go" => "Link After Previous Cue"
Thanks kimwida! Easy if you know, isn't it?
I found out that the 'delay in' controls how slow/fast the cuelist is played. (I have 15 cues and change all 'delay in' times at once)
Is it possible to link this 'delay time' to a wheel while the cuelist is playing?
It's a bit difficult when I want to change the speed to open the playback panel each time and enter another value
There is currently no way to control the speed of a cue list. I think you might be better using a chase for this.
Hi niclights, you are right. Chases are exactly what I need instead of a cue list. Now I can except the speed also change the cross fade.
I have 'programmed' all functions under seperate handles (color, gobo, intensity, and so on) and it works great.
Thanks to chase me everytime in the good direction!
