Help urgent my mobile lost connection
Help urgent pls, my titan mobile always losing connection, after i restart again it can be fix, but it will happen again, plz any one know the problem?
Re: Help urgent my mobile lost connection
Make sure any Windows power saving functions are disabled, particularly any involving Usb.
I already do it, but still happen
Plzzz anyone still know what to do? Its still happen
Have you tried a different Usb cable?
Yes, i already try with 2 different cabele, and it can be use for about 1 hour or two hour, and it's stop again, amd i try with another cable, it can be use until the end of the show, is there any specification for the cable?
Any certified USB cable should do the job, shorter, i.e. a few feet, is probably better. You could also try different ports on your computer or try using a powered hub in case the port is not supplying enough power.
Users browsing this forum: No registered users and 181 guests
