Help urgent my mobile lost connection
alim6310
Postby alim6310 » 26 Jan 2018, 14:31
Help urgent pls, my titan mobile always losing connection, after i restart again it can be fix, but it will happen again, plz any one know the problem?
Re: Help urgent my mobile lost connection
Postby niclights » 26 Jan 2018, 15:21
Make sure any Windows power saving functions are disabled, particularly any involving Usb.
alim6310
Postby alim6310 » 26 Jan 2018, 15:31
I already do it, but still happen
alim6310
Postby alim6310 » 27 Jan 2018, 07:32
Plzzz anyone still know what to do? Its still happen
Postby niclights » 27 Jan 2018, 10:46
Have you tried a different Usb cable?
alim6310
Postby alim6310 » 27 Jan 2018, 18:53
Yes, i already try with 2 different cabele, and it can be use for about 1 hour or two hour, and it's stop again, amd i try with another cable, it can be use until the end of the show, is there any specification for the cable?
Postby Gregory » 27 Jan 2018, 22:13
Any certified USB cable should do the job, shorter, i.e. a few feet, is probably better. You could also try different ports on your computer or try using a powered hub in case the port is not supplying enough power.
