Using iPad as an extra touch screen
chien0721
Postby chien0721 » 15 Jan 2018, 09:26
Hi everyone,
Recently I am trying to run titan one on a 15" Macbook pro with Win 10 system. I figured out it would be nicer to have a touch screen attached when I am programming and running a show, so I am trying to use an 13" iPad Pro as an extra screen.
There is an app called Duet which allows you to make iPad become a touch screen when you connect it to a laptop. The touch function works fine when running the windows and all the other applications. However, touch function just disappear (disable?) after I launch Titan One, but it will work again after I minimize or quit Titan One in Win10. I try with MA on PC as well and it works fine as well.
Did any one try to do this before and have a solution about it?
Thanks a lot!
Re: Using iPad as an extra touch screen
Postby icke_siegen » 15 Jan 2018, 14:50
Try launching the Duet App as admin.
chien0721
Postby chien0721 » 17 Jan 2018, 11:25
icke_siegen wrote:Try launching the Duet App as admin.
You mean from windows or from iPad?
Postby Gregory » 17 Jan 2018, 11:41
The Duet application that you run on Windows should be run as administrator. In Windows a non-administrator application cannot perform some actions on an application such as Titan which is running as administrator.
