I have two PCs which installed Titan Simulator and am struggling to join them.
Is it possible to test networking two PCs with Titan Simulator??
Or just need two Titan One USBs for the minimum??
Networking Test
Re: Networking Test
kimwida wrote:I have two PCs which installed Titan Simulator and am struggling to join them.
it should be possible, can you two laptops ping each other, and what are your ip adresses ? A lot of computers have problems with networking when norton antivirus is running, do you have any anti virus running ?
Re: Networking Test
When you run Titan Simulator Titan HealthCheck should be shown if there are any issues detected. The check titled Echo Request Firewall Rule must pass for Titan to communicate with Titan on other computers. You can run Titan HealthCheck manually by browsing to the installation folder: C:\Program Files (x86)\Avolites\Titan Simulator. You should also ensure that both Titan.exe and TitanSimulator.exe are allowed through the firewall.
Re: Networking Test
A PC (Titan One v.10.1)
192.168.0.2
B PC (Titan One v.10 Simulator)
192.168.0.8
Lan Hub
192.168.0.254
eDMX1 Pro
192.168.0.111
A fixture attached with eDMX1 Pro. The lan hub attached with eDMX1 Pro and both PC.
After turning off both of the fire walls, ping is ok each other.
I turn off the defender, the only antivirus program.
I patched the fixture in A PC and it worked.
Then deleted the fixture and patched it in B PC and it worked.
Now I can control the fixture with A PC and B PC. (I think it means they see each other.)
But I can see only one PC in each Titan Net session view.
I turned on network discovery share option and I tried 10.x.x.x address but it didn't work.
Maybe the problem would be the lan hub.
When I tried remote app in my home, I couldn't connect to the Titan.
But when I tried it in my club, I could connect to the Titan.
192.168.0.2
192.168.0.8
Lan Hub
192.168.0.254
eDMX1 Pro
192.168.0.111
Re: Networking Test
which network location are the adaptors set to? Needs to be home or work public blocks the connection. also, can you disable te Windows firewall?
Re: Networking Test
I tried it in my club again.
Just turned off the firewalls and it worked so easily.
I think there is something wrong in the router of my home.
Thanks all your guys help!!!
Re: Networking Test
kimwida wrote:A PC (Titan One v.10.1)
Just in case this isn't a typo you can normally* only network together the exact same version of Titan. 10 and 10.1 won't work properly together.
*There were a few historic exceptions for some hardware-revision versions like 9.3 but that's the general rule.
Re: Networking Test
riscster wrote:Just in case this isn't a typo you can normally* only network together the exact same version of Titan. 10 and 10.1 won't work properly together.
You are right.
At home, I couldn't even see a PC in other network session.
In my club, I could see the other PC.
But as you said, I couldn't connect to it, because the version is different.
After upgrading v.10.1, I could see and connect the two PCs.
Users browsing this forum: No registered users and 129 guests
