HTP problem
kimwida
HTP problem
Postby kimwida » 27 Jun 2017, 14:51
Hi.
I don't use it but I just encountered it and I want to understand it.
I made a palette of 0% dimmer.
And I had a cue on a playback fader which only have 100% dimmer.
I know dimmer is HTP.
But I raised up the playback full, then click the palette(quick palette).
It goes 0% dimmer.
Is it right??
Or are there separate places in the system palettes and cues take place?
Re: HTP problem
Postby Gregory » 27 Jun 2017, 22:58
This is correct, intensity palettes effectively work as LTP until a playback is fired that changes the level (this does not include changing the level of an already active playback) or the fixture is cleared (this is still the case if it was applied as a quick palette and the dimmer has not been touched).
