I've just upgraded our Expert to 10.1 and can't load any of the shows saved on 10.0.
I get the following on screen:
An error occurred loading or saving the show:
Titan failed to load the show.
These shows continue to load fine when running in 10.0
Any suggestions?
Thanks,
Tim
10.1 Load show
TimGregory
Re: 10.1 Load show
Are they autosaves? Autosaves are not compatible across versions but quicksave or initial version should work fine.
TimGregory
Re: 10.1 Load show
Ah OK, I am fairly sure I tried a quick save but will try saving under a new name and see if that works
Thanks,
Tim
Thanks,
Tim
TimGregory
Re: 10.1 Load show
It seems there was an error in one of the cues that wouldn't let the show load.
Once I cleaned up the show a bit it loaded fine.
I am not sure why but I got an error log one of the times that didn't show on the rest of the attempts to load show.
The error log pointed me in the right direction.
Tim
Tim
