Visualiser Realizzer 3D
alisa.love
Postby alisa.love » 19 Apr 2017, 10:25
Hallo, I have Titan Mobile and I would like to use Visualiser what is called Realizzer 3D.
I don't understand what i need to do to be able to use it. Should I have an artnet box or other device?
Can I run it without external artnet box?
Thanks.
Re: Visualiser Realizzer 3D
Postby Gregory » 19 Apr 2017, 11:06
This should work fine and you do not require any external Art-Net box or similar. You can configure Titan to output Art-Net to any or all of your network adapters and Realizzer 3D can receive this. If none of your network adapters are connected you can install and use a virtual loopback adapter to use instead as in the video below:
Realizzer 3D Connect with Avolites Titan
alisa.love
Postby alisa.love » 20 Apr 2017, 15:23
Thanks, Gregory for your answer.
I am trying to connect Realizzer and there is the first step in the video with tapping some letters in 'Disc Operating System' window.
It is in second 0:15 and it's not possible to recognise letters.
Maybe you know which letters should i write there?
Thanks.
Postby niclights » 20 Apr 2017, 15:30
It is 'hdwwiz'. Note this is only for adding the loopback adapater. In most cases you shouldn't need this.
