When I was making a cuelist, I found something strange.
For your understanding.
1. Make a cuelist that have three empty cues.
2. Unfold it. Choose every fixtures and make them red by pallet. Record it to first cue as replace.
3. On playback view window, put a color chase to second cue in autoload column.
4. For continue, put the color chase to third cue in autoload column.
When I run this cuelist, third cue doesn't work. It just turn off.
After some hours, when I make second step to a cue and put it first cue in the cuelist, now it works.
What is the difference between them???
Chase in cuelist
Re: Chase in cuelist
It may be a problem with the fade times interfering with the autoload, you can try either setting the autoload times (in the second and third cues) to zero or changing the times to Use Individual Target Times.
