Hello
Our lighting designer is not trained with Titan, but hope to be able to make quick updates of cue in cuelist on the fly during the exercises. We use tracking and observing that the update follow 9.3.5 in V10 manual. How can we make quick updates of a cue and avoid that the updates actually update an earlier cue instead of?
Regards Eystein L.
Using Update to change tracked cues
Re: Using Update to change tracked cues
To update the current cue and track forwards to the next block ensure cuelist is connected then press RECORD/CUE/CUE (CUE is also CONNECT on some consoles).
Additionally, with the cuelist connected, after pressing RECORD/CUE you choose to update just the current cue only, track backwards or track both back and forward by toggling to the appropriate option on softkey G before pressing CUE to end.
Thank you niclights
Until we got your answer, we used your second choise. The first choice gave us the neccessary effective way to work. And as an additional effect, we are able to edit the aattributes in cues in the cuelist without exiting to top menu.
