Changing Location of fixture as group
zahoorjury
Postby zahoorjury » 28 Sep 2016, 19:18
Normally when patch fixtures the capture shows all in front of back wall, how can change the group position to left or right sides of the stage ( I know solo one by one can be adjust )
Re: Changing Location of fixture as group
Postby Gregory » 28 Sep 2016, 19:36
With the wheels set to Visualiser and the group selected, toggle the Position attribute bank to show Rotate Y on the centre wheel and change the value to 90 or 270 degrees. Then toggle back to Position and change the X, Y and Z as required. Note that you can use Fan when changing Position to spread out your fixtures.
zahoorjury
Postby zahoorjury » 02 Oct 2016, 18:18
Hi , sorry for asking too much , what is the quickest and easiest way to arrange fixtures location in ROUND shape in Capture,
Thanks in advance
Postby niclights » 02 Oct 2016, 19:06
Unfortunately I don't think there is any particularly easy way at the moment.
I would probably split into two groups, position as two lines one above the other, then use fan (set to 'pull middle') to get a diamond shape. After that it will need manually tweaking to make a circle, probably by moving as pairs if there are an even number.
