Changing Location of fixture as group
- zahoorjury
Normally when patch fixtures the capture shows all in front of back wall, how can change the group position to left or right sides of the stage ( I know solo one by one can be adjust )
- Attachments
- image.jpeg (134.69 KiB) Viewed 5322 times
Re: Changing Location of fixture as group
With the wheels set to Visualiser and the group selected, toggle the Position attribute bank to show Rotate Y on the centre wheel and change the value to 90 or 270 degrees. Then toggle back to Position and change the X, Y and Z as required. Note that you can use Fan when changing Position to spread out your fixtures.
- zahoorjury
Hi , sorry for asking too much , what is the quickest and easiest way to arrange fixtures location in ROUND shape in Capture,
Thanks in advance
Thanks in advance
- Attachments
- IMG_0566.JPG (118.29 KiB) Viewed 5308 times
Unfortunately I don't think there is any particularly easy way at the moment.
I would probably split into two groups, position as two lines one above the other, then use fan (set to 'pull middle') to get a diamond shape. After that it will need manually tweaking to make a circle, probably by moving as pairs if there are an even number.
