Is This a little BUG ?
AndrewRPage
Postby AndrewRPage » 29 Jul 2016, 17:22
Enjoying trying V10, new stuff and old.
Using Titan 1 and PC and external touch screen.
Select a set of moving lights, any.
Select FAN.
If I move the software wheel with the mouse they fan as expected.
If I put the mouse at the center of the wheel display (how i usually use it for Pan/Tilt etc, as its more accurate) and use the mouse wheel they pan or Tilt as a group and un fan.
Re: Is This a little BUG ?
Postby Gregory » 29 Jul 2016, 19:02
It depends slightly on your point of view. Using the mouse wheel over the attribute view is supposed to increment and set all fixtures to the same value, this is mostly because the mouse wheel does not give the same acceleration information that the wheels on the console would give. The downside of this is that it is not possible to adjust values and keep their relative values nor use functions like fan. It was for this reason that the virtual wheels above the display were added to allow for this kind of control on TitanOne. This will have been the same in all previous versions of the software as well.
AndrewRPage
Postby AndrewRPage » 29 Jul 2016, 19:16
Ok.
I've obviously not done it that way before.
I know now.
Follow the logic.
Answer is buy a desk and get real controls.
Its on the wish list.
