External Touch Monitor w/ Expert Pro
Jsarge36
Postby Jsarge36 » 16 Jul 2016, 00:57
I hooked an external Touch Monitor to an Expert Pro. When ever I touch anything on it though the touch activates on the Titan Touch Pad. How can I separate their interaction to use the External for extra pallet options?
Re: External Touch Monitor w/ Expert Pro
Postby Gregory » 17 Jul 2016, 17:51
You will need to configure the external touch screen to assign it to the correct monitor/display of the console. If it is a Window Touch compliant then there should be an option for that under Tools > Control Panel > Touch Screen Setup, for other touch screens there is usually a setup utility provided with it.
Jsarge36
Postby Jsarge36 » 18 Jul 2016, 23:40
Thanks.
I had to install the drivers for the screen which I had hoped would be generic and then go thru the Tablet Settings in Control Panel.
