External Touch Monitor w/ Expert Pro
I hooked an external Touch Monitor to an Expert Pro. When ever I touch anything on it though the touch activates on the Titan Touch Pad. How can I separate their interaction to use the External for extra pallet options?
Re: External Touch Monitor w/ Expert Pro
You will need to configure the external touch screen to assign it to the correct monitor/display of the console. If it is a Window Touch compliant then there should be an option for that under Tools > Control Panel > Touch Screen Setup, for other touch screens there is usually a setup utility provided with it.
Thanks.
I had to install the drivers for the screen which I had hoped would be generic and then go thru the Tablet Settings in Control Panel.
Users browsing this forum: Bing [Bot] and 14 guests
