hi,
is there a tudorial on how to make the xml files ?
Or is there a way to save the macro you made on a console to an xml file ?
custom macro question
Re: custom macro question
Unfortunately no there isn't any documentation for macros currently, hopefully we will be able to provide some over time. For the time being look at the XML files for the factory macros and work from there.
I have written a macro which should allow you to export a macro from a show file to an XML file. The functionality to do this has not really been used or tested and will only work for Titan PC Suite (i.e. not on consoles). It will export the macro with user number 1.
- Attachments
- ExportMacro.xml
- (565 Bytes) Downloaded 1043 times
Great - I can confirm this macro does exactly what it is supposed to do. It exports the macro #1 into the file %userprofile%\documents\Titan\Macros\Macro1.xml
Gregory wrote:Unfortunately no there isn't any documentation for macros currently, hopefully we will be able to provide some over time. For the time being look at the XML files for the factory macros and work from there.
could it be that this macro stopped working in V10 ?
In version 10, it should export to the user macro directory which is in your Documents folder on PC or on the D drive on consoles.
Gregory wrote:In version 10, it should export to the user macro directory which is in your Documents folder on PC or on the D drive on consoles.
thanks
